Here are a couple of quick pics of the Hurst shifter on a T85 OD transmission. Even this bracket will need a bit of modification--the shifter came off of a big early 60's Ford and the OD lever on the Stude overdrive just BARELY clears the bracket--with a bolt and cable installed it WILL hit the bracket. Should be no big deal to alter the bracket by either moving the shifter up about 3/4" inch. This will take a bit of cutting and welding. OR I might be able to just bend the bracket about 1/8" for clearance. Either way, it's an easy mod. Of course, the THIRD alternative would be to just forget the OD cable and leave the OD "engaged" at all times.
And don't freak out about the wingnuts on the shifter levers--they are only there for a quick fit and pic!!!
