I have a '49 2R-10 with a bent straight axle, from the tree that hit it. I also have a '47 M-5 chassis that I'm scrapping. My question is, will the straight axle from the M-5 bolt into the 2R-10? The way the 2R-10 is parked in the garage, with everything around it, I can't get under the front to see. I know I'm going from 3/4 ton to 1/2 ton, and from 6 lug wide pattern to 5 lug small pattern, but I don't plan on hauling tons of weight in it anymore, if I haul anything, so I don't mind the difference. I have an old set of '41 Champion hubcaps that I think I might put on it to cover that little discrepancy up if this works. As you can tell, I'm not exactly concerned about being completely correct on every bolt with this truck. So does anyone know if the axle will bolt in?
Straight axle help
As you mention the bolt patterns are different. I have a 2R10 I am parting out if you want the axle from that. I am located in Virginia.
I know the bolt pattern of the lugs is different, but I'm wondering if the axle will bolt in. I have no problem with two different patterns on this truck. I would take you up on that correct axle, but I'm up in PA and it's not really even worth the drive for me to come get it. My axle is bent behind the drivers wheel, has been for about ten years. I never really drove it that often, and the most problem I had was uneven tire wear. I could probably find one around here if I actually looked, it just never was that important to me to do so. I just figured that since I have this one, and I'm scrapping the M-5 frame anyway, I'd see if it would work.
So.... does anybody know? Let me clarify a bit here. I don't exactly have the spare funds available to go looking for a correct axle, buying it, and driving out to wherever to get it at $4 a gallon (but thanks for the offer, Guido!). And this truck isn't exactly a candidate for full restoration, so I'm not worried about the front and back wheels matching. The guy I got it from was a Studebaker dealer and LONG time SDC member, and it was so bad that he wouldn't SELL it to me, so he said just take it. I haven't even thought about changing the axle for a while, as the truck has been buried in the garage I rent for six years. I just figured that since I was scrapping this frame anyway, maybe I'd get lucky and this one might work. Like I said, I can't see under the truck to match it up the way it's buried, I just thought that someone here might know off hand. As long as it will bolt in, I'd be fine with just using the M-5 front wheels on it.
For now, I'll just leave the axle in the garage and scrap the rest of the frame. Maybe I'll get lucky and it will work.
I believe the track is the same on the M and C cabs pickups. I would take some measurements and check. If the spring perches are the same it should work.
1952 Champion Starlight, 1962 Daytona.Searcy,Arkansas
"I may be lazy, but I'm not shiftless.""In the heart of Arkansas."
That's what I was wondering, if the axle would bolt to the spring perches. Everything else is simple. The shocks and brake lines are easy to work around. I'm worried about where the axle actually bolts up to the springs. If I can get it on there, I'm set. I guess I'll have to dig the front of the truck out and get under there to see if they'll line up.
You might try an alignment shop thats been around for years. It has been common practice on straight axles & on Ford twin i beams to heat & bend the axle to get proper alignment to spec's. Ford's for years had such a wide range for their spec's that it was common for an alignemnt shop to bend the axle to eliminate excessive tire wear. If you were out here I could recomend Johnsons Alignment in Torrance, Ca. but I'm sure you could find one in your area.
60 Lark convertible
61 Champ
62 Daytona convertible
63 G.T. R-2,4 speed
63 Avanti (2)
66 Daytona Sport Sedan59 Lark wagon, now V-8, H.D. auto!
60 Lark convertible V-8 auto
61 Champ 1/2 ton 4 speed
62 Champ 3/4 ton auto
63 G.T. Hawk R-2,4 speed
63 Avanti (2) R-1 auto
64 Zip Van
66 Cruiser V-8 auto
