Clutch pedal and brake pedal
  • Clutch pedal and brake pedal
    I cannot get them off! I have loosened the clamp that is on the end of the shaft that goes through the frame. But the shaft seems to hit something when I try to slide it to the right. According to the diagram in the book it should just slide out and let both pedals loose. It will move about an inch or less and it sounds like it hits solid metal when I try to move it to the passenger side. I am guessing it has some kind of "keeper" to keep the shaft from coming out if the clamp loosened up but cannot figure out where it is.
    Thanks for everyone's help,
    Jimmie
    1950 2 timer
    Orleans, Indiana
    sigpicJimmie
    Orange County, Indiana
    1950 CHAMPION -ORANGE COUNTY, INDIANA
    I think there's a woodruff key in the left end of the shaft that needs to come out of its keyway.
    Dwain G.
    Restorations by Skip Towne
      You are right, the woodruff key showed up as I kept cleaning off years and years of gravel road dust and grease.
      Thank you,
      Jimmie
      1950 2 timer
      Orleans, Indiana
      sigpicJimmie
        Thank you,
        Jimmie
        1950 2 timer
        Orleans, Indiana
        sigpicJimmie
          Good tip- something else I didn't know. Thanks!
          Parish, central NY 13131
