My 53 has a 2 large loops or hooks attached to the bottom of the frame about at the firewall. The hooks are attached with big (3/4"?) bolts. One hook is damaged. They appear like something you would use to tie down when transporting on a trailer and I can't see any other use for them. Since I am currently in process of restoring the frame on the way to a restorod, would there be any reason not to remove the hooks? Should I fill the holes? Put the bolts back in?
Rob in ND
Rob in ND
