The break lights on my 61 Hawk come on and stay on while the car is setting in the garage. They are not power brakes. It did it once when I first parked the car and I tapped on the brake pedel and they went out. I disconnect the battery when they are stuck on and often when I hook up the battery the next day they are no longer stuck on. Do I need a new sending unit? Is there a relief valve not working properly? Has the system been over filled with fluid? I adjusted the travel in the pedal but I have had the problem before and after the adjustment.
Brake Lights Have a Mind of Their Own
