63' Cruiser:door sill weatherstripping install ???
  • 63' Cruiser:door sill weatherstripping install ???
    ....I'm installing my new w/seals from SI I got @ York this past March. They seem to be fitting pretty good. My question is on the 4 door sill w/seals. I know this car has original w/seals on it. It looks like originally there was one (1) long w/seal installed for both floor sills on each side. Between both doors, there is a relieved section for rear door opening and closing so not to "catch" and tear the rubber. The w/seals I got from SI are 2 per side. My dilemma is: do I run the 2 pieces abutted the entire length and cut back some in the middle for the rear door, or just cut 2 pieces for each door ??
    ....well, I decided to run the sill seals all the way across the rockers. I did cut out some relief areas for the door closure and so far so good.....
