The syncronizers in Bess' tranny have gone bad. Also, the OverDrive howls when it's engaged. Bess is a 56B-D4 (Commander Parkview wagon) and I have a '52 Commander sedan. Both are V8s. So, is the transmission from my '52 Commander compatible? They look the same...
Could someone with the '52 shop manual look up the transmission for a '52 commander and tell me the model number? I can compare this to Bess' '56 OD tranny and see if they're the same. Then again, the '52 is 6 volt and the '56 is twelve. Since the govenour and the solenoid would be different, due to the differing voltages, would it be possible to just switch them and install the tranny?
As far as I know, the '52s transmission was fine thirty years ago. Certainly, it's in better condition than the one I'm currently using. The question is; Can I just switch trannys[?]
Home of the famous Mr. Ed!
Lotsa Larks!
Ron Smith
Lotsa Larks!
Ron Smith
