Hello to all,
I want to put a 5 speed manual trans on my 57 Stude off frame restoration. It has a champion 185 motor which I am rebuilding completely. I know it's been done successfully before, but I have some questions. Question 1---Which transmissions will work. I know it needs to have a manual speedometer cable so is this pre 1985 or so?? These transmissions are called t5's?? I also understand that mustang trans will work as well. Any suggestions on this?
Question 2---The car had a flightomatic in it so I will need the Stude manual bell housing. Is there any particular one or will "any" bell housing for that 6 cylinder engine work???
Question 3---I assume I will need the Stude flywheel or the starter won't work. But I don't understand how a Chevy clutch will hook up to the flywheel. I know adapters are available to bolt the trans to bell housing though. Cathcart sells or did sell the adapter plate, clutch and pressure plate and throwout bearing. Will this bolt directly to the Stude flywheel??? If no one knows the answer to this I guess I can call Bill Cathcart and he could tell me but I was hoping to cut some of the cost by buying the parts myself. I have the capability of making the adapter plate in my shop.
Any information is helpful. Your past help has speeded my restoration along. The project is proceeding well. I hope to get a rolling chasis with the engine and transmission in by the end of the summer.
As always --Thanks Dan
