My mechanic is pretty sure my 1965 Daytona has a turbo 350 transmission behind the 283. He says the pan looks right and the shifting puts 1st gear where the indicator says I am in reverse!
I have a few questions:
1. Does the 350 start in first or second gear? Is it a three speed?
2. Is there a way to change the shifting pattern to match the Studebaker pattern (is it PDNLR ?)
3. Is it a good transmission?
4. Are there kits or parts I need so the speedometer cable is hooked up properly to the transmission? Now there seems to be some mucked up homemade adapter that the car shop took out because the transmission fluid was leaking around it. So now I have no working speedometer .
Thanks.
Thanks.
