I've had that happen before, with the cylinder in the lock position and the door in 'unlock', but this is different - the key rotates fully to the lock position, and the plunger goes down, but the key won't come out of the cylinder, once locked. In the previous situation, the key would only turn part way, and the plunger would not go down.
I will check that, but I fear it might be a broken or missing spring (which I've just determined is the problem with the driver's door on Peter's truck)
