I need to know if the block is green and if the valve covers,intake and water pump are painted black ? Also if anyone has engine bay pictures of a 1951 commander restored to orignal colors.Thanks ,Daveg
1951 commander v8 engine color
Hi Daveg,
and welcome to the world's best Studebaker forum. You likely will get many great
responses.
The 51, 232 cu.in., V8 engine was painted an Army olive drab green. The valve covers were
black. I'm not sure what else was black.I think the pulley. Others will add and correct me
but this is the paint scheme I've seen. Studebaker International sells the right green
color #800254 in their catalog.
Dick Curtis
1950 Champion Starlight
1963 Hawk GT
Santa Barbara
CA
The 1950 Champion Starlight
Santa Barbara
CA
Below is a link of my 232 on my 1951 Land Cruiser that I restored earlier this year. You may have to scroll through some of the pictures, since I am chronicling the full restoration process. I pretty much painted the parts the same as what they were originally. I am certain the block colors are original from the factory, the yellow paint marker identifications on the block were still there. The block was OD green, fan, pulley, oil filler and water pump body were also OD green. The valve covers are semi-gloss black, the oil filter canister is gloss black if installed at the factory (mine was). I believe it was bright orange if it was dealer installed. I painted the dry type air cleaner gloss black as well. Hope this helps.
Originally posted by whacker View PostThe intake manifold should be bare cast iron to be correct. I have found that the "Cast Iron" hi temp paint fron Eastwood looks pretty close and prevents corrosion.
Replacement Oil Caps and Fan Blades were Black, all Factory Installed were Olive Green "Studebaker Green", 1950's Bell Telephone Truck Green, Packard Green and Military Green available at: http://studebakervendors.com
Originally posted by ronta View PostWhat color were the oil and auto transmission dip sticks, the oil filler tube cap, fan blades and pulley on a 1951 Commander Starlight Coupe 232 V8 engine? Ron Acton
Engine and Transmission Assy's were all painted complete Minus Electrics with Valve Covers covered, as they were already Gloss Black.StudeRich
