Are there any gas resistant sealers, Permatex, etc? I cut a gasket for the sending unit and wondered if a little sealer (gas resistant sealer) is indicated. If so , any suggestions are welcome.
gasket sealer... gas resistant
I don't know if Studebaker used any sealant on that gasket originally, but you can safely use the old style "Number 2" Permatex if you want to. It isn't affected by gasoline. Just remember to NEVER use any SILICONE sealer if it'll come into contact with gasoline.
Dave Bonn
Valencia, PA
'54 Champion Starliner
Dave Bonn
Valencia, PA
Only at just about any hardware store you can find.
Tom - Mulberry, FL
1964 Studebaker Daytona - 289 4V, 4-Speed (Cost To Date: $1826.83)
Tom - Bradenton, FL
Tom - Mulberry, FL
Tom - Bradenton, FL
Simple, it is gasoline soluble! It does not seal gasoline, read the label.
quote:Originally posted by curt
Why never use silicon sealer if it will com in contact with gasoline?
Studebakers Northwest
Ferndale, WAStudeRich
I don't think the factory used any sealer on that gasket. It was a cork gasket, and the screws had small copper washers under the heads to seal. The "new" replacement gaskets are now neoprene (I think) just like the valve cover gaskets. Hope this helps.
Dan Miller
Atlanta, GA
Dan Miller
Atlanta, GA
