I was out cruising at sunset with Barney last evening with all the windows down, listening to the V8 rumble I came to a stop light, and a gent pulled up to my right and said "Hey partner - you don't have any brake lights!"
Well this came as a surprise, since I had the headlights on and knew all four corners were working. I pulled into a nearby park and braced the brake pedal down while I checked the rear end and - sure enough - dark lamps. Turns out that the connectors that slip onto the master cylinder switch had become a touch loose and were not making adequate connection, so I squeezed them tight, verified operation and went home. Today I tightened them a bit with a crimp tool and added some dielectric grease to the studs to make sure it doesn't happen again.
So I'm sharing this just to remind everyone that the things you take for granted sometimes aren't living up to their end of the bargain. Give those brake lights a check now and then!
