50- 51 bullet nose question
  • 50- 51 bullet nose question
    A friend wants to know if a 50 bullet nose will mount on 51 car. I assume he means with no modification to the car.
    No, the mounting holes are different.
    1950 Champion Convertible
    1950 Champion 4Dr
    1955 President 2 Dr Hardtop
    1957 Thunderbird
      Yes, but mounting holes aside... will the 50 fit with nothing more than some holes drilled?
      sals54
        The large center hole in the sheet metal that receives the bullet is bigger on the 50 than it is on the 51 so the sheet metal has to be cut all the way around. It's more than just the mounting bolt holes.
          Yes, by cutting the center hole larger, as Roy said, and redrilling the mounting holes a 50 bullet will fit a 51. OP asked for no modifications and a 50 bullet will not fit a 51 without modifications to the sheet metal.
          1950 Champion 4Dr
          1957 Thunderbird
            Here is my 51 with a 50 nose. Not hard to install. Only drilled two of the holes different, a bit of the body round metal out. Hood is up a little in the first picture.
            51 Studebaker Starlight State Commander Coupe
            53 Studebaker Starlight Regal Commander Coupe
            62 Volvo PV544 Sport
              And see how much better it looks???? MUCH BETTER! ! ! Drill the holes. Its the way Jehosephat Studebaker would have wanted it.
              sals54
