I ran across parts of a 1953 2R5 truck that may be of use to me. It is a frame, both axles with wheels, drive train, cab with doors and seat. I like the frame. It is in better condition than my 1949 frame is, and the tube shocks would be an upgrade for me.
There are other parts attached to it, so I have questions:
1. Has anyone successfully sold a bare cab with doors (cab, 2 doors, each with 2 hinges, nothing else)?
2. Has anyone successfully sold a bed, 1 item, with no fenders or tailgate?
3. Has anyone successfully sold a seat, appears to have new upholstery, never used, but that 'new' is probably 20 years old?
If yes to any of the items above, then is anyone able to estimate what might I expect to be able to ask and successfully be given for these items?
4. There is a Commander engine installed. No generator, carburetor, wiring, fan, linkages, radiator, etc. It has a car's bell housing which puts the starter where it looks like the accelerator linkage needs to be, if it were there. I like the possibility of an upgrade to a Commander engine, but I would need all of the missing parts. Can the car's bell housing be made to work in a truck?
5. My 1949 parts manual shows a different part number for the Commander and for the Champion bell housings. Does this mean that I cannot bolt a Commander engine to my Champion bell housing?
6. If I install my existing Champion engine and bell housing into this frame, then is there a difference in the length of the two bell housings that would prevent me from using the drive shaft that is now connected to the overdrive transmission behind the Commander bell housing?
7. One question is answered in one of my earlier postings about my truck. The number on the overdrive solenoid identifies it as 6 volts, so that is a negative for me. It makes me believe that the starter most likely is also 6 volts, but I did not look at that.
Sorry, I did not get photos of this setup. I am told that this was a man's project, but he died before finishing. 10 or 15 years later his family sold what they had to another man who used some body parts then sold it to the current seller, so the work that was done to this setup is somewhere between 10 and 20 years old. The remaining body parts show no rust, but they are repainted, and I have no idea what is under the 20 year old new paint. I drove 8 hours to look at this. Hearing the seller describe his projects made it known to me that his asking price would be out of my league, so I did not ask, because I wanted to see it. I brought double what I wanted to spend, and his asking price is almost triple what I brought, so there is a gap. I ask my questions above because if I can get some of my cost recovered, then maybe I would be willing to go a little higher with what I want to offer, if I end up coming to an agreement with the seller.
Does anyone have advice for me? Thanks.
