Hi,
I'm just getting around to installing my Turner dual Master-Cylinder (under floor, 57 Golden Hawk) on my naked chassis. Now is the time to do modifications! I've tried searching the Forum, for suggestions for firewall reservoirs but find mostly broken (old) links. I plan to follow Jim's recommendations of drilling a hole between the chambers inside, and then only one hole in the exterior, and running a line up to the firewall. So the question is what the latest and "best" suggestions are for a reservoir and where/how to mount. Never done brake work before except changing pads and rotors on my modern cars, so appreciate any advice. Also, I've PM'd Jim too, but do you know if I need the adjustment/tuning valve since I'm keeping all four DRUM brakes? And if so, where does it go, front or rear line? (I know I DO need the 10# restrictors in both front and rear lines.....). THanks!
Barry
Barry
