What would cause the oil to overflow the oil filter canister along the lip of the lid as well as the hold down screw? This is a 6 cyl champion with the oil dipstick tube next to the firewall (drivers side) and the oil canister draining into the base of the oil dipstick tube. I replaced the intake line but not the outlet. The outlet is clear but it seems not to be draining fast enough, or the inlet is pushing too much oil? This wasn't an issue last fall. I've been doing some work to the truck and this is the first time I've started it since the fall. Changed the oil and filter as well. Not sure what the issue might be. Thanks.
The filter canister should drain completely when the engine is turned off should it not?
