any help would be great ,have a rear end out of a 63 cruiser that has a tag 3:54 ok, but it has a nother tag to says 45 , what does that mean ?
Rear end identifiation
Tags: None
Easier way to tell if it’s got twin traction: with transmission in neutral, just rotate one axle. If the other axle turns the opposite way, it’s NOT twin traction. If the other axle turns the SAME direction, it IS twin traction.1950 Commander Land Cruiser
1951 Champion Business Coupe
1951 Commander Starlight
1952 Champion 2Dr. Sedan
1953 Champion Starlight
1953 Commander Starliner
1953 2R5
1956 Golden Hawk Jet Streak
1957 Silver Hawk
1957 3E5 Pick-Up
1959 Silver Hawk
1961 Hawk
1962 Cruiser 4 speed
1963 Daytona Convertible
1964 Daytona R2 4 speed
1965 Cruiser
1970 Avanti
My 58 Transtar V8 Auto had TT and the way I found out was by trying to tow it around a corner. skeeeeeeerrrrrt. WTF?!?! so i jacked it up spun a tire, and Voila the opposite turned the same direction. then pulled the plug and tried to stick a finger all the way in. it hit the carrier. Once I ordered the Sheet from the Museum, it was confirmed the truck was built that way.
Topic moved: The "Found Online" section of the Sale board is for posting links to items you've found on the Interwebs. Please use Tech Talk for technical questions.
Originally posted by drrotor View PostEasier way to tell if it’s got twin traction: with transmission in neutral, just rotate one axle. If the other axle turns the opposite way, it’s NOT twin traction. If the other axle turns the SAME direction, it IS twin traction.Jerry Forrester
Forrester's Chrome
Douglasville, Georgia
Originally posted by dannyo View Postany help would be great ,have a rear end out of a 63 cruiser that has a tag 3:54 ok, but it has a nother tag to says 45 , what does that mean ?james r pepper
