This has been discussed in the recent past,but here we go again. I have read on this forum that blocking off the center exhaust ports to reduce carburetor heating can be a good thing to do. I have the intake manifold off and may as well do the blocking off while I'm at it. I have some forty thousandths stainless shim stock I can use.I will be using steel gaskets.Will the shim stock blocks seal,since they are not ridged? I can cut the center sections of the gaskets out,but will they seal? Is the change a good one? I run an electric fuel pump and a six bladed fan,but I still have idleing problems in the summer when idleing for very long. All suggestions appreciated.
Thanks,Marshall
Thanks,Marshall
