I've finally decided to convert my '51 Champion to 12-volt. It came down to at some point wanting--actually needing--air conditioning in the California farm country where I live.
Forum posts make it appear that the two-speed '53 and later electric wiper motor will bolt-in as a replacement for the stock '51 vacuum motor. I also see aftermarket conversion motors like New Port Engineering. I like that they offer an intermittent delay switch I'm curious about what others have found to be the best way to go, factory parts or the aftermarket, as well as what to avoid.
I also see that there was a factory windshield washer nozzle for '51. I've never seen one, but I assume it would mount in the cowl and shoot two streams of water at the windshield. I've used the nozzle from a VW Beetle on other cars in the past; they work well and are easy to adjust to put the water where you need it. How good is the stock Studebaker nozzle and is its spray adjustable?
Thanks for the help.
