Well since the TROG Rail Class car I discussed garnered a little interest, I figured I would start a build thread here for anyone who cares to follow along.
At at this point we have completely broken down the Model A chassis, drilled and modified the rails to sit completely parallel the entire length (similar to a Model T), then narrowed it 8 inches to keep it as skinny as possible. This will be a single seat, center-steer setup.
The Champion six will be a perfect fit, and isn’t physically much larger than the Ford 4 cylinder. It will be sitting just ahead of the chassis centerline to keep the weight distributed as evenly as possible. This should help with traction on the loose sand with skinny tires.
So here’s our mock-up with the engine/trans in the chassis. Lots of work to go, but so far we’re having a blast!
