Can anybody tell me what the front track is on a t cab? Is it 60" or 56 1/2"? I really don't know how to measure it. I want to put a heidts mustang ll front suspension on it but don't know what the track is. Thanks guys.
Front wheel track on a t cab
AFAIK, Studebaker did not include front track in their truck data books. Assuming you are asking about a half-ton T-cab, the width over the outside surface of the rear tires was 69 5/8". But as noted above, that assumed 6.70 x 15 or 6.00 x 16 tires on standard wheels.Last edited by Skip Lackie; 02-07-2019, 04:21 AM.Skip Lackie
In this instance I would be measuring the track of your truck the same way heidts measures the track of their front ends...that way you are comparing apples to apples, so if heidts measures from the wheel surface of the hub to hub, you should too. and as alan says you can always alter the track with different wheel offset/back spacing as long as you don't get too crazy going too far negative or positive from factory specs of what heidts specs are as that can create wheel bearing issues and geometry issues. cheers, juniorsigpic
1954 C5 Hamilton car.
Originally posted by junior View PostIn this instance I would be measuring the track of your truck the same way heidts measures the track of their front ends...that way you are comparing apples to apples, so if heidts measures from the wheel surface of the hub to hub, you should too. and as alan says you can always alter the track with different wheel offset/back spacing as long as you don't get too crazy going too far negative or positive from factory specs of what heidts specs are as that can create wheel bearing issues and geometry issues. cheers, juniorsigpicAnything worth doing deserves your best shot. Do it right the first time. When you're done you will know it. { I'm just the guy who thinks he knows everything, my buddy is the guy who knows everything.} cheers jimmijim*****SDC***** member
