I ordered a production order but in the meantime , I know someone here can give me info on serial number V258130. Thanks
VIN info
Originally posted by tim333 View PostI ordered a production order but in the meantime , I know someone here can give me info on serial number V258130. Thanks
If the V is a G, then it is a South Bend 1947 Champion.
If you are referring to the 1953 Commander that you just purchased from New York, that is the engine number. At that time (in NY and many states), cars were registered & insured (no title then) by their engine number.
To get the production order from the SNM, you will need the Serial Number.
Hopefully, the engine hasn't been changed or you may have "hoops" to jump through when you go to register, title & insure the car..Gary L.
Originally posted by tim333 View PostIt’s a Massachusetts title, that’s the number used. Let me rephrase, I’m ordering the production order once the car gets here and I get the number off the pillar.Gary L.
V258130 checks out as a 1953 Commander 232 V8 Engine.
Found right here: http://www.studebakerdriversclub.com/V8EngineID.asp
This Number will be Stamped INTO the rear Top corner of the Block on the machined flat Pad.
UPDATE: Correction; I was thinking 1951 & '52 for some reason, the Stamping is on the Left Front Top Corner of the Block on '53 and On V8's.Last edited by StudeRich; 01-14-2019, 08:25 PM.StudeRich
Originally posted by StudeRich View PostV258130 checks out as a 1953 Commander 232 V8 Engine.
This Number will be Stamped INTO the REAR Top corner of the Block on the machined flat Pad.Gary L.
Car Serial Number 8,290,001 was the first 1953 South Bend Commander, so 8,338,201 just makes it one of that Model Year's Production.
I would call it somewhat Late 1953.
8,354,901 is the first 1954 Commander, all numbers that can be found in your Chassis or Body Parts Catalog.StudeRich
How about some pictures of the car?RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Nice! I bet you can hardly wait.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Originally posted by tim333 View PostNumber is 8338201
The Serial Number indicates a South Bend build, yet it has the trim of either a Vernon (LA) build or a two-tone car. I assume that the car was originally one of the two-tone combinations.
The production order will give you lots of information.Gary L.
