I installed a refurbished gas tank, new fuel lines and sending unit on my 49 Champion and I can't get the fuel gauge to work. I tested the wire from the gauge by grounding it to the frame no gauge movement. I put a 12v test light between the gauge wire and the ground and noticed a dim light, so I know some juice is getting through. I then checked the voltage at the sending unit and found 3.5 volts. Next I put a solid 6 volts to the gauge from the sending unit and got a full reading on the gauge. The only thing I can figure is that the gauge is sticking until it gets a more voltage.
Your opinion please, any input would be appreciated........Thank H Smith
