My 52 Commander came with a broken alternator bracket that was made from a modified generator bracket. I replaced it with a Studebaker bracket, but it was about 3/4" too short for my belt to run true. I kept intending to make a new one, but it was working and we still had not gotten the MIG welder going. The issue became more urgent when the Studebaker part broke into.
The only instructions I found were on how to convert a generator bracket for an alternator so I decided to build my own version and see how it works. The stock generator bracket is 3/8" thick, the Studebaker bracket is 3/16", so I decided to try 1/4". I think the 1/4" was as thick as I could have bent cold anyway. It was tough, but with a bit of hammering I got it done. I ended up welding the pieces with my oxyacetylene torch. Time will tell how this holds up, but it lines up very well. I made the space for the alternator a bit wide to allow for adjustment with shims if needed, but I got lucky with the fit.
I took it back off for pictures and some paint. The drawing is a combination of hand drafting and some lettering and touch-up using the Paint program on my computer. I hope it helps someone.
