bearing retainer for t10
Tags: None
I would ask the seller if the throw out bearing portion of the retainer is 1 1/2" in diam. That part is narley looking. Rusty, funky and over priced already. I would put up a want add on the board here or call A&A gear on Washington Blvd. in L.A.
If the Super T10 works, they are like $30 and readily available. But the ST10 might have a bigger bearing. I think if you hit the internet you should be able to find one under $50.
I know I have 1 spare. If I have a few spares, I'd sell one.
To bring this back up.....
I have been thinking about swapping the t10 I have into my Lark. I have also been looking at hydraulic throwout bearings.
Being that I am leaning on going hydraulic for the throwout bearing, if I want to install this, I should be able to get a Chevy ( 1 3/8) bearing retainer and be good to go if I get the 1 3/8 throwout bearing. No?Charles
1961 Lark Regal VIII 259/auto -- Lucy
Do you already have a clutch pedal?
Hydraulic is never as good as Studebaker mechanical. Is it a 61 Lark with floor pedals? They are the very best for precision clutch action - you can feel the throwout bearing tapping on the cover fingers. If it has suspended pedals, there is a bell crank which pivots on the inboard side of the frame. This is OK for a stock type clutch - HD racing clutch another matter. Still, I'd get the pieces for this. If you are missing the clutch pedal entirely, I'd still get the conversion pieces - the floor mounted would be easier to convert.
If using a Chevy, get the Chevy style Studebaker bell housing and all you'll have to do is get a Stude front bearing retainer and turn a simple bushing for back of the crank.
AND it would be all stock too.
