mechanical advance electronic distributor
Not sure what engine you have, but this is how my 289 is set up. (from another post) I have an adjustable vacuum advance. You might too, the adjustables are hex shaped just below the hose nipple and have an adjusting screw inside the nipple. The weight springs are very dependant on the weights and their cam, so try it and see which works. Never seen those lock out tabs before.
I don't run mine with ported vacuum, it's connected directly to the manifold. I set the timing at the IGN mark at 700rpm with vacuum advance disconnected. Connect the vacuum and advance goes up 3 degrees. By 1500rpm the mechanical advance is all in at 30 degrees. By 2500rpm the combined vacuum and mechanical advance brings total advance to 45 degrees. Runs like a scalded dog, no pinging or temp issues.
