On the big belt line chrome strip on the doors the clips have all popped off. It had 4, now there are none. How does one repair those clips? Or does one have to resort to 3M emblem tape? Or is there another method? TY
Chrome strip clips 54 Commander
Body / Glass: Chrome strip clips 54 Commander
1942 Packard Clipper Custom Touring Sedan * 1952 Studebaker Champion Regal * 1954 Studebaker Commander Regal Starlight * 1967 Thunderbird Hdtp * 1969 Continental Mark III * 1969 Mercury Marquis convertible * 1972 Buick Riviera * 1973 Continental Mark IV * 1978 Glass Top Lincoln Town Car * 1983 Mercedes 300SD * 1986 Dodge RAM 4WD * 1999 Infiniti Q45Tags: None
I had planned on using the emblem tape, but I picked up some two part epoxy for metal, with a claimed strength of 2900 pounds. I haven't had a chance to try it yet, but will let you know if the clips can be put back with epoxy.Tom Senecal Not enough money or years to build all of the Studebakers that I think I can.
Originally posted by tsenecal View PostI had planned on using the emblem tape, but I picked up some two part epoxy for metal, with a claimed strength of 2900 pounds. I haven't had a chance to try it yet, but will let you know if the clips can be put back with epoxy.
I got all of my chrome and pot metal redone and just got to putting it back on. I reamed the holes out larger to avoid to much pressure on these fragile clips and all but 2 have popped off when I was trying to work them in the holes. I used my needle nose to squeeze them and limber them up and greased the holes. No luck about the time I think they are going to seat the little washer pop off and the clip detaches. NUTS and double nuts. I went to town and bought 3M emblem tape. It is so thin that I stacked it up 4 times. It doesn't have the holding power since there is tension on those long belt line strips. I was sure someone else on the forum has experience with this. I have not had luck with epoxy before. Let me know how your project goes with the epoxy.1942 Packard Clipper Custom Touring Sedan * 1952 Studebaker Champion Regal * 1954 Studebaker Commander Regal Starlight * 1967 Thunderbird Hdtp * 1969 Continental Mark III * 1969 Mercury Marquis convertible * 1972 Buick Riviera * 1973 Continental Mark IV * 1978 Glass Top Lincoln Town Car * 1983 Mercedes 300SD * 1986 Dodge RAM 4WD * 1999 Infiniti Q45
Originally posted by tsenecal View PostI had planned on using the emblem tape, but I picked up some two part epoxy for metal, with a claimed strength of 2900 pounds. I haven't had a chance to try it yet, but will let you know if the clips can be put back with epoxy.Gary L.
Car porn
Originally posted by rbigcal View PostDid you check restoration specialties for clips ? How wide is it ? In some cases the christmas tree fasteners will work by sanding off the round sides so they will slide inside the molding.Last edited by poweroptions; 08-15-2018, 07:04 PM.1942 Packard Clipper Custom Touring Sedan * 1952 Studebaker Champion Regal * 1954 Studebaker Commander Regal Starlight * 1967 Thunderbird Hdtp * 1969 Continental Mark III * 1969 Mercury Marquis convertible * 1972 Buick Riviera * 1973 Continental Mark IV * 1978 Glass Top Lincoln Town Car * 1983 Mercedes 300SD * 1986 Dodge RAM 4WD * 1999 Infiniti Q45
There were 2 types of attachment used as I recall.
Sounds almost like you have the type where there is a flat plate about 1-1/2" long held to the door with 2 screws and there is a "button" on the chrome that snaps onto this plate. The other type has a plate riveted or staked onto the chrome that has a springy knob protruding that snaps into a hole in the door.
Both kinds have issues.
The first type, the door mounted clips are a pain to get aligned so the buttons on the chrome snap into them. Then, they get rusty eventually. The other type, the plate/springy knobs break off the chrome as they are attached with just the pot metal casting having cast in pins peened flat.
If its the 2nd type, if you have the broken off part, I would try sanding the back of the chrome and cleaning up the plate and try JB welding it back together. May have to file/sand the cured material if too high and prevents the chrome from going all the way down. I dont know if the pot metal casting is thick enough there to risk drilling a shallow hole and adding stubby screws or not.
My own '53 has the door mounted clips with 2 screws and fussy shim washers. I got replacement doors from a '55 that had the other type and I had to weld up all the other holes and drill new ones for the clips.
Jeff in ND
Originally posted by Jeff_H View PostThere were 2 types of attachment used as I recall.
My own '53 has the door mounted clips with 2 screws and fussy shim washers. I got replacement doors from a '55 that had the other type and I had to weld up all the other holes and drill new ones for the clips.1942 Packard Clipper Custom Touring Sedan * 1952 Studebaker Champion Regal * 1954 Studebaker Commander Regal Starlight * 1967 Thunderbird Hdtp * 1969 Continental Mark III * 1969 Mercury Marquis convertible * 1972 Buick Riviera * 1973 Continental Mark IV * 1978 Glass Top Lincoln Town Car * 1983 Mercedes 300SD * 1986 Dodge RAM 4WD * 1999 Infiniti Q45
The product that I purchased is JB weld steel reinforced epoxy. It states on the package "Strength 2424 psi". I will be trying it today, and will report back as to how it works out. I had looked at several different versions, and had remembered 2900 psi, but that was not the steel reinforced one.Tom Senecal Not enough money or years to build all of the Studebakers that I think I can.
No, don't even think about mig welding. Pot metal is a zinc based alloy with a low melting temperature around 800F or less. For pit repair they grind/drill out the pits then copper plate it. Then they can solder fill the pits over the copper as the solder will stick to that (but not the raw pot metal). Solder melts at less than 1/2 the melting point of the pot metal or 360-380F or so depending on the type.
I would only consider soldering those clip plates if these were stripped down to the bare copper and only if they had not yet been replated as the heat from soldering is sure to discolor the chrome IMO.
If all that fails, you may go with that thicker double sided foam tape, or another thought is use something like "marine goop". That stuff will stick about anything but it can be runny until it sets up and you would need to figure out how to hold the trim in place in the meantime. I would avoid those solutions as if you need to remove the trim later it may not want to come off and get damaged in the attempt.
Jeff in ND
Originally posted by Jeff_H View PostNo, don't even think about mig welding. Pot metal is a zinc based alloy with a low melting temperature around 800F or less. For pit repair they grind/drill out the pits then copper plate it. Then they can solder fill the pits over the copper as the solder will stick to that (but not the raw pot metal). Solder melts at less than 1/2 the melting point of the pot metal or 360-380F or so depending on the type.
If all that fails, you may go with that thicker double sided foam tape, or another thought is use something like "marine goop". That stuff will stick about anything but it can be runny until it sets up and you would need to figure out how to hold the trim in place in the meantime. I would avoid those solutions as if you need to remove the trim later it may not want to come off and get damaged in the attempt.1942 Packard Clipper Custom Touring Sedan * 1952 Studebaker Champion Regal * 1954 Studebaker Commander Regal Starlight * 1967 Thunderbird Hdtp * 1969 Continental Mark III * 1969 Mercury Marquis convertible * 1972 Buick Riviera * 1973 Continental Mark IV * 1978 Glass Top Lincoln Town Car * 1983 Mercedes 300SD * 1986 Dodge RAM 4WD * 1999 Infiniti Q45
I cut some screws off with a dremmel, and drilled out the bumps on the pot metal that is supposed to hold the clips. The screws have to be VERY short, and you have to be extremely careful in drilling the posts. One full turn of a screw is good to hold, and as an added insurance use a dallop of JB Weld in the screw hole. I did this on my very first car in l972.Bez Auto Alchemy
Originally posted by bezhawk View PostI cut some screws off with a dremmel, and drilled out the bumps on the pot metal that is supposed to hold the clips. The screws have to be VERY short, and you have to be extremely careful in drilling the posts. One full turn of a screw is good to hold, and as an added insurance use a dallop of JB Weld in the screw hole. I did this on my very first car in l972.1942 Packard Clipper Custom Touring Sedan * 1952 Studebaker Champion Regal * 1954 Studebaker Commander Regal Starlight * 1967 Thunderbird Hdtp * 1969 Continental Mark III * 1969 Mercury Marquis convertible * 1972 Buick Riviera * 1973 Continental Mark IV * 1978 Glass Top Lincoln Town Car * 1983 Mercedes 300SD * 1986 Dodge RAM 4WD * 1999 Infiniti Q45
Originally posted by altair View PostI just got some rare clips from Steven Allen's in Florida, he has a large inventory of Studebaker clips. Also check with Jurassic Parts they equally have a large inventory of clips.1942 Packard Clipper Custom Touring Sedan * 1952 Studebaker Champion Regal * 1954 Studebaker Commander Regal Starlight * 1967 Thunderbird Hdtp * 1969 Continental Mark III * 1969 Mercury Marquis convertible * 1972 Buick Riviera * 1973 Continental Mark IV * 1978 Glass Top Lincoln Town Car * 1983 Mercedes 300SD * 1986 Dodge RAM 4WD * 1999 Infiniti Q45
