View Full Version : Brakes: Another idea for power brakes
Dan White
08-14-2018, 08:33 AM
I saw this on ebay and I think it might be another way to add power brakes to Studes and others. These are used on Lexus hybrid SUVs. I don't see any connection to Antilock, just 12V. Might even be able to do it under the floor. Would need 12V and under floor would need remote reservoir.
https://www.ebay.com/itm/2007-2011-LEXUS-GS450-GS450h-BRAKE-MASTER-CYLINDER-UNIT-OEM-LOT337/123126614204?fits=Make%3ALexus&hash=item1caaeb08bc%3Ag%3AiLgAAOSwD5pa9bgW%3Asc%3AFedExHomeDelivery%2119707%21US %21-1&_sacat=0&_nkw=lexus+450H+master+cylinder&_from=R40&rt=nc&_trksid=p2047675.m570.l1312.R1.TR11.TRC2.A0.H0.XLexus.TRS1
Bordeaux Daytona
08-14-2018, 09:56 AM
I was looking on alldata and it looks like that cylinder thing below the master cylinder is called a brake stroke simulator and it plugs into an abs/skid control module so it probably won't work without it.
Paul Keller
08-25-2018, 01:22 PM
One of the large "Internet/Mail Order" brake system suppliers advertised an electric booster for around $1,000 - And, no I do not recall which supplier (last year it was advertised in many of the car magazines).
Paultk
Edsel G. Tattooer
08-25-2018, 01:51 PM
Here is a quick search for a electric brake booster for much cheaper from many sources.
The expensive one must be from Speedway they seem to have one for like $1300
https://www.google.com/search?q=electric+brake+booster+vacuum+pump&client=firefox-b-1&source=univ&tbm=shop&tbo=u&sa=X&ved=0ahUKEwjGv7ux74jdAhUM9YMKHdXkBp4QsxgIKA&biw=1536&bih=728
64Avanti
08-25-2018, 05:10 PM
These are not brake boosters, they are vacume pumps that are used to provide adequate vacume for a vacume brake booster.
Edsel G. Tattooer
08-25-2018, 05:35 PM
DOH!
Not all are.
Here is the one Mentioned above
https://www.speedwaymotors.com/Compact-Electric-Brake-Power-Booster-Master-Cylinder-Disc-Disc,8335.html?sku=10410564&utm_medium=CSEGoogle&utm_source=CSE&utm_campaign=CSEGOOGLE&gclid=CjwKCAjw_IPcBRAjEiwAl44QkQLZGZnk9GjA3pOhw--Woxg7RQakobP0C2XsZMyJplNgpV_hb7JqoBoCTJwQAvD_BwE
Mike Van Veghten
08-25-2018, 05:36 PM
A better idea...just use the proper sized master cylinder.
I've driven two and am building another Stude (brand has no bearing) with either disc-drum, or disc-disc, and used no big heavy, space wasting, ugly power booster. The disc-drum car was pretty much a normal stopping car, while the disc-disc car is a two toe stopping car.
The floor mounted pedal length is just right, and I assume that the hanging pedals are very close in length to having a good lever arm length.
Do a little homework and save money and space, just get the right sized master cylinder for the calipers you are using.
