Hello again,
I have rechecked the float level and purchased a gauge to check the pressure of the fuel pump. It read between 2 and 2.5 pounds. I checked the idle screw and the needle and seat, also. I read in my "shop manual for 1936 models" that the economizer valve may need to be taken out and lapping using fuller earth and liquid soap. I can still get it to fire then it floods out. I have to take off the vacuum advance line from the manifold and drain out the gas. I can't seam to find what is causing this problem. Anyone have any ideas?
Thanks,
Dennis
Thanks,
Dennis
