I know that it is slim but I have been looking for a power steering control valve for my 61 Hawk that I have had repaired but it still leaks fluid. I would like to find a NOS that someone has in there long forgotten archives or at the least a used one that is dry.
61 Hawk power steering control valve
Did you pull out the aluminum hose seats, and dress them on a lathe? If not your new hoses will leak because they will not seat into the deeply grooved old ones.Bez Auto Alchemy
Originally posted by Swamper714I had the repair done at a reliable Studebaker repair shop, so I will be in contact with them as far as that is concerned but I do not believe that is where the leak is coming from. Thank you for your information.
He rebuilds these and also supplies complete power steering setups.
He is in your neck of the woods
Mine has always been a little drippy and I've had my 61 since it was 9 yrs old. Working on a 63 Galaxie which has very similiar PS and it doesn't leak. The little rubber seals on the Ford are different than a Studebaker which look like brake cylinderseals. Has anyone tried using the Ford type in a Studebaker??
Originally posted by Jeffry Cassel View PostMine has always been a little drippy and I've had my 61 since it was 9 yrs old. Working on a 63 Galaxie which has very similiar PS and it doesn't leak. The little rubber seals on the Ford are different than a Studebaker which look like brake cylinderseals. Has anyone tried using the Ford type in a Studebaker??
There should be more info out there, probably on Bob Johnstone's site, so I suggest taking some time searching.Paul
Winston-Salem, NC
Check out my YouTube channel here: https://www.youtube.com/user/r1lark
