Would anyone have the diameter of the original tach? Right now I have a non working aftermarket tach and would like to replace it. I haven't found an original one yet so I thought about a newer Stewart Warner style. Does anyone have recommendations?
'62 GT Hawk Tachometer
Speedo / Tach / Gauges: '62 GT Hawk Tachometer
Jim Kaufman
Kearney NE
1952 2R10
1953 Champion (sold it and still kicking myself)
1962 GT Hawk
1963 R3984 Avanti R1Tags: None
3 3/8" I've been looking at this Stewart Warner "delux series" from Summit Racing. It's the closest the in appearance to the stock gauges I could find. https://www.ebay.com/itm/Stewart-War...19.m1438.l2649
Originally posted by bensherb View Post3 3/8" I've been looking at this Stewart Warner "delux series" from Summit Racing. It's the closest the in appearance to the stock gauges I could find. https://www.ebay.com/itm/Stewart-War...19.m1438.l2649
Thanks!
Thats a good question Joe, if you find out let us know. A couple years ago I put the internals of a new Sun tach into the stock GT tach case, with the stock needle and face. I also have a GM HEI, it worked fine for a while but now won't go above 1500 rpm. I've had a GM HEI in my Ford for over 30 years, the Sun tach in it worked for 25 years before it started acting up.
The one above has only two reviews on Summit, but they are bad: rusting bezel, and slow moving needle. This one looks more promising, and higher quality, for only a little more money: https://www.ebay.com/itm/Auto-Meter-...53.m1438.l2649
Originally posted by JoeHall View PostThe one above has only two reviews on Summit, but they are bad: rusting bezel, and slow moving needle. This one looks more promising, and higher quality, for only a little more money: https://www.ebay.com/itm/Auto-Meter-...53.m1438.l2649
This is the one I used in my 62 GT Hawk with my Unilite Distributor. No problems, looks and works great.
SWW-82162
Tachometer, Deluxe, 0-6,000 RPM, 3 3/8 in. Diameter, In-Dash Mount, EachLast edited by Mrkelly; 05-09-2018, 05:59 AM.Mike Kelly
Regional Manager
Texas
1963 Lark Cruiser
1962 GT Hawk
1965 Commander 2dr v8 auto
Thats the same one I posted earlier. Good to know it works well with the Unilite. If I remember right, that's just an optical trigger replacing the standard points and uses a stock coil, correct?
Originally posted by bensherb View PostThe only problem with it is it doesn't begin to resemble the stock gauges. The bezel cant rust it's painted.
I see SPEEDWAY MOTORS has a 8000 RPM for $114. Its cheaper than the 6000 RPM, plus I just tuned the ole girl up so an 8000 RPM Tach might be needed now....yes this is a LOL statement. https://www.speedwaymotors.com/Stewa...Inch,7120.htmlJim Kaufman
Kearney NE
1952 2R10
1962 GT Hawk
I have a very nice tach I never installed in my 63 R2 Hawk as I ended up fixing the OEM tach in the car. Contact me, I’ll send a pic and make you a great deal. Tim at hoesa81@yahoo.comLast edited by tim333; 05-09-2018, 01:15 PM.
Check out your boat parts dealers, I got a boat tach from someone on this site for $50.00 new in the box. Installed it two years ago and it works great. Looks very close to the stock, 6000 RPM. Made by Veethree Instruments. Veethree Electronics and Marine, 2050 47th Terrace East, Bradenton, FL, 34203.Tel 941-538-7775, Fax 941-775-1222, www.v3instruments. com. techservice@veethree. com. Don't know if any of this is currant, it's from the instruction sheet. the only thing wrong with it is the bezel is not chrome, it's grey, but it has the same shape as the stocker. If I ever pull it out, I may try to fit the stocker. -Jim
Originally posted by tim333 View PostI added a pic, it’s yours for $95 plus shipping from 60404.
Thanks.
email sentLast edited by JoeHall; 05-09-2018, 04:25 PM.
