View Full Version : What Year is this Champ Pickup?
TWChamp
04-29-2018, 07:18 AM
Someone in Illinois saw this Champ in the junkyard the other day. It looks like it might be worth restoring, if the bottom rust isn't too bad.
I'm just wondering what grill is in it, and what year the Champ is? Thanks, Tom
72084 72085 72086
Bud
04-29-2018, 07:41 AM
The truck was built between 1960 and 1962. The 1963 and 64's have hanging brake and clutch pedals. The grill has to be from a 1959 to 61 Lark. Bud
StudeNewby
04-29-2018, 07:56 AM
The 1960 models had three indentations above the rear window, which this one lacks. The trim on the right front fender is not the funky 1961 "kick up" style, so along with Bud's spot-on analysis, I'd say it's a 1962 7E.
jackb
04-29-2018, 08:47 AM
field truck or lawn ornament only..... unless you've got 2-3 parts' trucks out back...
62champ
04-29-2018, 09:45 AM
Looks to be a 7E5-122, 3 sp/OD. VIN should fall between 132601 and 135600. As Jack mentioned, might be good for just ornamental purposes. Floors would be the determining factor. If it can be picked, factory rear bumper (and its brackets), should be saved. If the padded dash does not have any holes or cracks, it has value as well.
Bill Pressler
04-29-2018, 11:31 AM
Yes, the wide bed and lack of the 'kicked up' moldings, along with the non-suspended pedals inside, indicate a '62, the highest-sale year for Champ.
04-29-2018, 12:22 PM
That has to be the FIRST for a backwards Grille swap! :ohmy:
You see a few '59-'60 Larks with Champ Grilles installed, but I have never seen a Champ with a '59 Lark Regal Grille before.
The '59 and '60 Grilles Both fit with or without the Regal Surround Moulding, but a '61 is a No Fit, being narrower and Longer.
http://forum.studebakerdriversclub.com/attachment.php?attachmentid=72086&d=1525004265
A '59 Lark Grille and Regal Moulding with a '59 Lark (Hawk) Ornament in the '60 Location, on a '62 Champ Truck.
Warren Webb
04-29-2018, 12:51 PM
The grille texture looks like a 59 Grille. I see what looks like the accessory oil pressure & amp gauges in the area usually found for the radio. If those are what they appear to be grab 'em
WLB
04-29-2018, 09:15 PM
I would like to put a Lark grill on my 62 Champ if it would fit
62champ
04-29-2018, 09:20 PM
'59 and '60 model Lark grills will fit without any modifications - bolt on change - good luck.
Milaca
04-29-2018, 10:21 PM
In my opinion, it is only worth scrap metal price.
62champ
04-30-2018, 08:49 PM
When they return - ask if they could take a photo of the VIN plate so it can be added to the 7E registry. Thanks.
