I have a couple of questions. I am working on this 51 Commander. I am working on the fuel gauge. I want to know if it is a bad gauge. There are 6volts going into the gauge when the key is on. There are no volts coming out through the sending wire. The sending wire is good. The sender is grounded to the tank and the body and is known to be a good ground. The sending unit has resistance after being checked with it attached to the tank and ground check. The gauge does not move at all when the key is on. Suggestions?
Second question. What are the electrical connections for on this part of the column by the steering box? I cannot find the parts in the book.
51 Commander, 232 Automatic drive.
