Well, I got my dash back in and wired. Thought I would check the wireing with an ohm meter to ground for shorts. I started under the hood with the 5 lug terminal strip on the fan shroud. All show short to ground. Then went to the voltage reg. Same thing on all terminals. Battery side of starter solinoid also short to ground.
I did add ground to the instraments by attaching the ground wire to the mounting lug on each instrament cluster. Did not see where the ground to the instraments comes from.
John Ratliff
John Ratliff
