I am converting my 88 Avanti with the chevy 305 to old school carb. & distributor doing away with computer controls Am I going to have a problem with the 700r transmission
1988 avanti transmission
Tags: None
Bez Auto Alchemy
Are you going to use a stock Quadra Jet carb? It should have a correct hookup for the throttle pressure cable. If not you will need an adapter for the Edelbrock carb, available from the seller, just tell them what you are installing it on a 1988 Monte Carlo. I would use the smaller Edelbrock , the 650 is too big. Lou Cote
