Lark Map Light is broken
Tags: None
Dorman has one found at Rockauto should be able at any auto parts store
Originally posted by creegster View PostLook what I found at Autozone. Sweet!
[ATTACH=CONFIG]70245[/ATTACH]John Clary
The broken one in the original post is a dual contact insulator. Had me puzzled too, but it has 2 contact holes but only one wire and contact.Originally posted by jclary View PostUnless I'm missing something, you need to take that one back and exchange it for a "single" filament bulb. The one you show here looks perfect for a double element bulb, but not a map/dome light.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Originally posted by thunderations View PostThe broken one in the original post is a dual contact insulator. Had me puzzled too, but it has 2 contact holes but only one wire and contact.
The bulb may use one filament for the switched power at the light housing and the other filament for the door switches.
Originally posted by creegster View PostThis looks right to me: the original was a double-filament as well. IE, it has 2 contacts on the base of the bulb. Some parts shot out of the housing when I was working on it, and I dont know where they went, so they are not in the original photo.sigpic1966 Daytona (The First One)
1950 Champion 4Dr
1957 Thunderbird
Originally posted by 8E45E View PostAs per the Owner's Guide, they use a 1004 bulb, which is double-filament. https://www.autozone.com/electrical-.../16805_0_18269
CraigJohn Clary
There was a time when you would see scads of these late model "used" dome lights, including the cover and lens, for a buck or two at Studebaker swap meets.Dan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
There are single filament with dual contact bulbs for a variety of applications where the assembly is not used as a ground where one of the wires is connected to ground. I have wired some lighting this way to assure a good ground. This type of assembly is used in marine applications where the body is fiberglass where there is no continuous ground. This also works well around rusty tail lights and anywhere where a good grounds are questionable.
Studebaker actually sold those 'fiber discs' as a repair item. We have a bin tray full of single wire types.... Not sure If we have a disc for two wires or how many.
Anyone need single wire discs?
Now days a good dome assy is 20 bucks in good condition. (evil vendors! )
