I bought a scrap engine from a 1953 2R5 truck a while ago for the accessories. It has been handy for that. The seller included a steering wheel, shaft, box, column shifter assembly. I presume the truck that it came from sat for many years without windows because the top of the steering shaft cover tube and the column shifter are rusted beyond being usable. It was removed by cutting a tie rod, so the pitman arm is still installed on the box. The box does appear to be usable. It steers nicely and does not show any play by moving the pitman arm by hand. It shows no sign of ever having leaked fluid and is full of a shiny black sticky semi solid something.
I think I may be able to install this box in place of the box that is on my truck, which has a lot of play, binding, and leaking.
My reading of the repair manual has me believing I should do something like this:
1. Take the steering wheel off. The picture in the manual is very dark, but it looks like I need to make a plate to allow my puller to pull the back side of the hub of the steering wheel.
2. I would then be able to remove the steering shaft cover.
3. If the steering shaft rod appears to be useable, then I will be able to install that assembly into my truck. The condition of the inside of the steering box leads me to believe that I will not have to disassemble it, unless I have to in order to change the steering shaft.
4. If the steering shaft is not useable, then I will need to disassemble the box to exchange it for the shaft that is in my truck now.
5. If I need to disassemble the box, then I need to remove the pitman arm. My Harbor Freight puller has, so far, not been able to move it from its shaft. If I do not need to disassemble the box, then I need only to remove the end of the tie rod from the pitman arm.
Do I need to make the plate for my steering wheel puller?
Does any of my plan seem reasonable or the right thing to do?
The gap in my pitman arm puller is too large to get more than a small grip on the edges of my pitman arm. Mashing the gap smaller with a press does nothing because the gap expands out again while pulling on the tapered pitman arm surface. Would anyone recommend a little heat? My source would be a home plumber’s propane bottle torch.
