In an attempt to clean up and toss 50 years worth of paper, I came upon some original Sun Electric Corp spec sheets concerning the R-series Studebaker's.
Concerning the R-1 and R-2 specifically:
Running dwell is stated as between 32 and 36 degrees..........I then noticed a tiny (*) at the bottom with the following information:
Max variation (off factory spec) is 2 degrees in either direction.......which means running dwell can be as low as 30 degrees, or as high as 38 degrees.
I wonder why Studebaker never made this additional information readily available?
After 25 years with the same set of points, my running dwell is a steady 31 degrees, which pleases me greatly, guess my steady maintenance has payed off in spades.
