View Full Version : Trunk gasket.
Jerry Forrester
10-13-2017, 04:37 PM
Which is the best way to install trunk rubber seals?
This way?
https://i.imgur.com/R1HbMZl.jpg?1
Or this way?
https://i.imgur.com/FW71hT4.jpg?1
Studebakercenteroforegon
10-13-2017, 04:43 PM
First picture, lip facing out.
62champ
10-13-2017, 04:45 PM
Have always wondered why someone has not found a newer style gasket that would squeeze over that inside lip and leave most of that channel open for all the "stuff" to be able to move down and out...
10-13-2017, 05:03 PM
IF that is the Left Fender & Body Side, then the 1st. Pic.
IF it is the RIGHT Fender, then it's the 2nd. Both looking from the REAR?
52-fan
10-13-2017, 05:31 PM
You can see the shifter inside the car. Looks like the left side to me.
Jerry Forrester
10-13-2017, 06:03 PM
You mean like this.
https://www.amazon.com/Vertical-Bulb-Trim-Seal-Diameter/dp/B00LBZR7M2/ref=pd_day0_469_4?_encoding=UTF8&refRID=GVX808D0FS3Y5CTPQ2ES&th=1
Reasonable in cost. I may just buy a small piece and try it. A one foot piece is only $2.75.
Jerry Forrester
10-13-2017, 06:04 PM
Thanks to all of you.
It is the driver's side.
JoeHall
10-13-2017, 10:31 PM
Does not make one bit of difference, its still gonna leak anyway. LOL
altair
10-14-2017, 12:11 PM
Are you sure that is the correct seal for the trunk? I bought a kit from SI and the trunk seal looks slightly different.6776867769
Jerry Forrester
10-14-2017, 04:28 PM
The only thing I'm sure of is death and taxes. This was in with the bunch of Stude rubber I bought from Kent (a great and fair Stude guy by the way).
It looks like my rubber will work better than your rubber. <G>
Jerry Forrester
10-17-2017, 05:58 PM
Got my trunk rubber installed yesterday.
https://i.imgur.com/CihutdY.jpg
sweetolbob
10-17-2017, 06:06 PM
Can you pull a Benjamin from the closed truck seal area? ;) IAC, nice work. You make excellent progress when you put your mind to it. Bob
Jerry Forrester
10-17-2017, 06:21 PM
If and when I get the trunk lid on, I'll let you know. <GGGGGGGGGGGGGGGG> I hope not. I might try a Washington first and work my way up to a Benjamin.
swvalcon
10-18-2017, 08:10 AM
Jerry Who's trunk rubber are you using?
Jerry Forrester
10-18-2017, 09:03 AM
Steve,
PM sent.
SScopelli
10-18-2017, 09:24 AM
You mean like this.
I have used that type of seal on the trunks. The Lark's trunk inner lip works well with this type and debris that gets in the cracks can easily be washed out since the channel is not blocked by so much seal.
