Missing Parts for Champ Overdrive
  • Transmission / Overdrive: Missing Parts for Champ Overdrive
    Hello all. I was wondering if someone could point me in the right direction to find the parts I need for the overdrive in my 64 Champ. I have the solenoid on the transmission. Everything else has been removed, including the lever. Thank you.
    I envy you. My '62 Champ has the 4-speed trans with the first gear "granny gear". If all you have is the solenoid you will need the governor, wiring harness, relay, and the control assembly. Check page 144 of the 1962-1963 Truck Parts Catalog.
      Hi ,you don't need a relay as there was a change in 63 , I may have a harness and governor , I will check in a couple days , We have a 64 Champ Six with o.d. and its a wonderful thing , We got almost 26 mpg driving it to So.Band this year , Ed
        There were two overdrive transmissions. T85 and T86 and some overdrive parts were different.
