A bit off the Studebaker theme, but since so many are using this trans now days,,,
I've finally started driving the Avanti around after installing the TH700R4 conversion (been busy with other things, so it has been a delayed start). The OD trans works a treat when cold/warm, but on super hot days (90+) it will not shift into OD after a while. (This has nothing to do with the converter lock up, I haven't even hooked that up as yet.) I've got the geometry right on the TV/carb link, and the shift points are good, nice kick down, etc. Everything is as expected unless it is a really hot day, then it works fine until everything gets hot, then it fails to shift into 4th (OD). One issue I have, is that the trans cooler in the radiator is not yet connected, but I have a rather large trans cooler in front of the radiator. I have not done any temp or pressure measurements so far.
Now, here is the strange part. I have a model A Ford with a 2.8L Chevy V-6 in it, and a TH700R4 trans. It has the exact same issue, on hot days it won't shift into 4th (OD). That one does have the converter wire connected, and again, it all works as expected when it is not hot outside. (By hot, I mean 90 degrees plus.) On the model A, at first I thought maybe since it is a small engine, and has a ton of wind resistance, perhaps my foot was just into it so far at speed that I'd reached the shift down point, but that proved not to be the case, after a careful analysis. Again, since there is not any trans cooler in the model A radiator, I have a large cooler under the model A in the air flow (no fan).
It just seems strange to me that I don't turn up a bunch of Google hits on this type of problem, since I have two vehicles with the same symptoms. I'm hoping there is a trans expert on here that has seen this and knows what is happening, or at least can give me some ideas. By the way, both of these transmissions are MM (men's mall) items, so not freshly rebuilt or anything, but both had hardly any junk and fresh looking/smelling oil when I pulled the pans to have a look (my only method for determining their condition).
Ideas from knowledgeable transmission people are appreciated.
