50 pickup vin is RA51359 could not find any info online.. Thanks Todd
Can anyone decode my vin#
Not sure about the letter "A", but '49-53 1/2 ton (2R5) serial numbers started with R5- followed by number, example R5-12345. I think they started with 0001 in '49. If you are not aware of this, Studebakers used separate serial, engine and body numbers, none of which match but all show up on the production orders.
When I was unpacking last night I found old registration cards for the '49 2R5 pickup I bought in 1974 and the '46 M-16 dump truck I bought in 1976. The one for the M series is dated 1957 and probably the last one, as the original owner was killed in 1958 while helping a motorist change a tire.
Stude truck serial plates were stainless steel with some black lettering and stamped numbers. Most were spot welded, though some seem to have escaped the welder and were only held on by two sheet metal screws. You might find evidence of the holes by looking at the back/underside of the seat riser (not that it will help much). Your DMV should be able to tell you if that's a state-issued VIN.Skip Lackie
