Short Circuit
  • Electrical: Short Circuit
    My son's 1955 Champion with a 185 six developed a short circuit yesterday, luckily he managed to disconnect the battery before any fire could start. He's in the Army and based 1,000 miles south of me, so it looks like I'll have a plane trip in my near future. Because he's not that experienced with old cars and has no workshop facilities on base I'm trying to diagnose the problem so I take the right parts with me on the flight. Here is what happened;
    He'd just gassed up and went to start the car, it started three times then died after a few seconds each time. One the fourth attempt he said smoke started coming from under the dash, he jumped out and opened the hood to disconnect the battery and noticed there was smoke under the hood too. The cable running from the solenoid to the starter has melted the insulation, and so too the power cable that goes from the ignition switch to an after market radio I fitted - this cable has a 15 amp in-line fuse. He's at work today (Monday here), and is getting me photos this afternoon. He said before any of this happened the car was running normally. I'm leaning towards the ignition switch. Any ideas would be helpful.
    Cheers
    Matt
    Matt
    Brisbane
    Australia
    Visit my Blog: http://www.mattsoilyrag.blogspot.com.au/
    Is it the original 6 volt positive ground?
    I'd bring some wire and a test light or multimeter along. A poor connection can also overheat and burn wires, but that burn should be next to the poor connection, while a short will burn the wire along the entire length. Look under the dash for any wires shorted to ground.
      Yes, it's the original 6 volt positive ground. Thanks.
      Matt
      Brisbane
      Australia
        The bad wire is going to be one of the crispy ones. Did the 15 Amp fuse blow? That might be a clue to what happened first. When replacing that wire, put the fuse as close to the ignition switch as possible to eliminate un-fused wire that could short out . Is the starter wire running close to anything it could wear on or be heated up by? Insulated clips to hold it away from harm would be in order. Good luck and let us know what you find.
        1950 Champion Convertible
        1950 Champion 4Dr
        1955 President 2 Dr Hardtop
        1957 Thunderbird
          Don't forget that an overheated wire with melted insulation can droop and contact another, unrelated wire and short that one out too. That's often what causes whole wiring harnesses to go up.
          Skip Lackie
            My son sent me up some photos of the damage, it looks worse that I thought and can't really see the extent of it. So looks like the trip down is off and I'll have the car shipped back home to papa for repairs. Now the issue of finding a car carrier who will ship a non-running vehicle - a lot won't, and the ones who will want an arm and a leg!
            Thanks all for your comments.
            Matt
            Brisbane
            Australia
              Can you clip some burnt wires and hotwire it just to drive it home?
              Have to hotwire due to hot wires. LOL
                I did think about doing that, but it's a 1,000 miles from home, (roughly the same distance from South Bend to Houston), and I don't know if there has been any other damage done by the short - generator, lighting, instruments etc, and the plane tickets to get down there are about $500. I would hate to get down there and find I can't hot wire it to run and still have to get it shipped home after spending on the airfares.
                Matt
                Brisbane
                Australia
                  Matt;
                  I think I would rent (if I did not have) a truck and trailer. Pack some tools and drive down. If I could not repair the car, then trailer it home. Or have my son load the car on a trailer and bring it home.
                  I did that when my Avanti transmission front seal would no longer keep the fluid in the transmission.gave up the ghost in Gettysburg Pa. If I remember correctly It cost about $600 for the trailer and 1 ton truck one way for 400 miles.
                  I was lucky when my daughter was in Grad School in Chicago (about 1000 miles from NY) for 5 years; we were able to have the car fixed in Chicago, when needed. Costly, yes but cheaper then a 2000 mile trip with the car twice .The first time she needed a car in Chicago; the wife and I drove her 98 Pontiac ( I know it was not a Studebaker) out and took the train back home.
                  Ron
                    If the car still has its original wiring, chances are that you`ll find a lot of cracked or missing insulation of you thoroughly check it. The best solution is buying a new wiring harness from Studebakers West or one of the other Stude vendors. This was replaced on my `47 Champion about 15 years ago, and was definitely worth every cent spent and every minute used.
                    Bill Jarvis
                      Originally posted by Ron Strasser View Post
                      Matt;
                      Ron
                      NY to Chicago is about 800 miles. Perhaps it just seemed like 1000 or you took a scenic route.
                        Looking at a possible diagnosis, the starter may have a short whereas the armature is going to ground. If the armature is grounding the line from the solenoid will almost instantly become red hot. This will in turn heat up the solenoid and the small solenoid starter wire back up to the ignition switch and possibly further on to your radio circuit. The fuse may not blow immediately because there is no load on that circuit. I would therefore suggest the problem is with the starter motor. A possible quick test would be to bump start it and not use the starter and see if it runs even with the burnt wires, if the gods are not with you, turn it off immediately. When the battery is reconnected if the circuit is still closed stop there, if open then only try to bump start.
                          Hi Matt- I bought a 1962 GT from a gent in the Hunter valley (Maitland ) last year and had it freighted to the northern Suburbs of Melbourne. It cost $785 total. The brakes were not functional hydraulically, except for the handbrake. This carrier was the best price given to the non functional hydraulics- 'Door to Door car Carriers and delivered within the same day as pickup. http://www.doortodoorcars.com.au
                          Regards Steve, SCCA Victoria
                            Hi Matt, Man am I really sorry to hear of the unfortunate issue with Ziggy. I'm glad the young owner didn't get hurt,and the Champion didn't get burnt ! curious how many miles are on the odometer now ?
                            Joe.
                            Joseph R. Zeiger
                              You have a real puzzle here. Looking back at the beginning your starter and ignition system were functioning normal enough to turn the engine over and fire it up for three or four times and the problem was it wouldn't stay running. I've had two ignition switches go bad and cause the same problem. Then there is the smoking wire to the radio which means there is more current flowing through the wire than it is rated for. Possible causes the wire is pinched to ground before the fuse holder or the radio is shorted and the fuse is too big. I have experienced a healthy starting system smoke the heavy battery cables when cranking longer than normal. What sticks in my craw is the radio wire. It is possible that a dead short on the wire would allow the engine to crank and fire up but when the key is released to run position shunt the primary voltage to ground killing the engine. What ever the case may be it looks like you are the victim of a snow ball effect. I would remove the radio wire from the ignition switch then proceed like previously suggested to hot wire the ignition give it a push start and see if the engine stays running then back track from there. Where did you find a modern radio that is 6 volt positive ground?
