If no fluids go in...No fluids come out! Seems simple.
Can my 289 and FOM ever be made to stop leaking completely?
Seems like removing the concrete floor in the garage would solve the problem. I keep some large pieces of cardboard to place under the cars. So far the cardboard has lasted a couple years, so the leaks must not be too bad. I have found that searching and fixing leaks can be a full time job. Once you fix one, the pressure goes to the next weakest place and you have created another problem. As things wear and age dries out seals, leaks are to be expected. I'm talking drips, not streams here. Good luck on your quest.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
One of the posts on here really got to me and I feel the need to speak. "A Studebaker is like a Harley, if it's not leaking oil that means it's more than likely is out of oil." They do not leak oil. Even the old Harleys do not leak oil. That happens to be the automatic chain oiler.....................Hey, maybe Studebakers have an automatic chain oiler
Originally posted by bosshoss61 View PostOne of the posts on here really got to me and I feel the need to speak. "A Studebaker is like a Harley, if it's not leaking oil that means it's more than likely is out of oil." They do not leak oil. Even the old Harleys do not leak oil. That happens to be the automatic chain oiler.....................Hey, maybe Studebakers have an automatic chain oiler
I have owned a 52 'K' Model Sportster (at 16 years old), 47 Indian Chief (at 17 years old), a 61 Pan, 67, 70 & 72 shovel (between 1975 and 1981), and currently an 86 FXRD, for the past 10 years or so. The 86 comes closest to not leaking, but more accurate to say, it doesn't leak "much"Last edited by JoeHall; 10-23-2013, 12:49 PM.
When I acquired my Daytona, a very leaky car, I removed the drive train for a full reseal. The FOM proved to remain significantly leaky. After a clean off of the FOM, it appeared that the leak was originating at the fill tube bracket on the side of the pan. Removed the trans pan again for close inspection and found a burn through on one of the spot welds. That was the leak. Since this was a low mileage original, it had obviously leaked since it left the factory. You just never know! Clean up the trans with spray cleaner and study where the oil is leaking. Don't overlook the vent fitting also.Last edited by WCP; 10-23-2013, 06:40 PM.
Update on my leaks...
Replaced:
Oil Pan Gasket
Real Main Seal
Transmission Pan Gasket
Tailshaft Seal
Tailshaft Bushing and Driveshaft Yoke (when we pulled it out, about half the yoke was galled, as if it was just sitting in a corrosive liquid for a long time. To ensure the seal we did the bushing, yoke and seal)
Happy to say 99% of my leaks are gone for the moment!
Still occasional drips from the front of the engine, but I'm satisfied for now!
Thanks for all the help!Last edited by pbrown; 12-24-2013, 08:35 AM.
Originally posted by Doug Bowen View PostIf the front of the engine is an issue...I agree with what was previously posted regarding the lip seal conversion on the timing gear cover. Works great.
D
