Results 1 to 5 of 5
Thread: Dana 44 Thrust Blocks
    President Member wdills's Avatar
    Oct 2009
    Eastern NC
    949
    Does an "Open" Dana 44 have the axle trust blocks/buttons like the Twin Traction (limited slip) version of the Dana 44?
    Wayne
    "Trying to shed my CASO ways"
    Jan 2008
    5,222
    No, the axles just butt up against the spider gear cross shaft.
    Bez Auto Alchemy
    573-318-8948
    http://bezautoalchemy.com
    President Member Xcalibur's Avatar
    Jun 2013
    Kansas
    866
    Ah, yes. The beauty of springing for the Parts and Shop Manuals. The Parts Manuals clearly shows the two differentials "exploded."
    President Member acolds's Avatar
    Mar 2007
    South hills, Pa, .
    512
    The Studebaker parts book shows part for non locking as part number 530451 (1002-11 Plate 10-2 Rear Axle) Thrust Block . A surface is needed to set the axle end play.
    Oct 2009
    Eastern NC
    949
    I am back home now so I can get my hands on the manuals. I see that the "Open" diff has a single thrust block that is retained by the cross shaft. It is nothing like the little button type blocks used in the twin traction. Therefore no way for the thrust block to fall out when the axles are removed. I was concerned that I may have lost those little buttons when I pulled the axle out of this "Open" diff.
    Wayne
