Bell Crank hits radiator
Are all the mounting holes on your 55 in exactly the same places as on the Hawk?RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Did this on my 53 Turbo Coupe. took some fiddling with rad. support, ground a little on rod end also. believe i may have used a different support as car was built from bits and pieces but it all works with a 1/2 in clearence.between rod end and rad. Luck Doofus
I have used a chevy starter shim under two of the bell crank bearing block bolts to tilt them to gain clearance. A single shim spans both bolts is why.Last edited by bezhawk; 03-20-2017, 07:46 PM.Bez Auto Alchemy
573-318-8948
http://bezautoalchemy.com
I cannot think of any Parts that matter that are different from a '55 C or K Model to a Hawk Steering system that would prevent it from being a "Bolt-on".
However if you have a Sedan or Wagon you have several problems.StudeRich
Looking at the 63 Set up, looks like 1/2" is, what it is. Remember the motion in the bell crank moves it away the further from center you get and neither the radiator nor the bell crank move in relation to each other (hopefully) so what ever it is, it should be okay. Many Avantis with short style engine mounts have less clearance from the top of the ball end to the crank pulley, and they get away with it-even with the engine moving around. Only way I could see getting a more comfortable clearance would be to find a way to move the radiator further forward-but I don't think there is enough room do that and close the hood. Or, you can do what Studebaker did to get pan clearance on the tie rod end of the bell crank--dent it with a hammer, but probably would get the bottom radiator tank to leak.
Originally posted by jrlemke View PostHow thick is the shim? -JimBez Auto Alchemy
573-318-8948
Originally posted by altair View PostI would not recommend fiddling with the steering geometry as serious turning errors will occur. I would look at shimming the radiator forward, maybe only at the bottom.Bez Auto Alchemy
573-318-8948
