Thread: PCV Valve
    Mar 2006
    180
    PCV Valve
    Anyone have a part number for a PCV valve that will work on a 259? I need one that is 3/8" barb fitting on both ends.
    Millsboro, DE
    2,212
    What year 259 CA only or other? Don't have any numbers except 289 Avanti screw in style. If a universal style will work (not the best way) https://www.summitracing.com/parts/s...FYKKswod_B4BJA
    https://www.summitracing.com/parts/b...0299/overview/
    https://www.summitracing.com/parts/b...0315/overview/
    Mar 2006
    180
    It's a 62 Lark. There is a 3/8" line from the lifter valley to the carb and the PCV valve is just in the middle of the line. Looks like the second part you listed from Summit should work. All the ones I found before were 1/2" or bigger on one side.
    Millsboro, DE
    2,212
    Remember, each valve is designed to allow a certain flow--a controlled vacuum leak--so you may need to try more than one, in case it makes your car idle too high-low, or seems to screw up your performance too much. I wasn't able to locate the "right" one on any of our vendors websites, so it will be trial and error. When you find one that works-please post here for someone else in need.
    This list hasn't been updated in years but some of them still help in locating substitute parts no luck on the pcv valve interchange from delco though
    http://www.northstarwheel.com/resources/interchange.pdf
    27,403
    All of the applications for that valve are 4 Cyl. Engines, that may not have ENOUGH Flow!
    There should be some AC (GM) brand PCV valves available that are for approx. 300 c.i.d. or less Chrysler or GM V8's.
    AC and Norris Thermador made almost all of the New York/Calif. requirement to Register/Plate, 1961 PCV conversion Kits for U.S. V8's and 6's.
