Results 1 to 8 of 8
Thread: Fuel Line Size ?
    989
    Fuel Line Size ?
    What size steel fuel line runs from the tank to the fuel pump on a 56 Hawk? Thanks...
    3,548
    Should be a 5/16" if that is what it came from the factory.
    27,054
    I believe it's a Sky Hawk, so that would be correct, same as all Stude. V8's except '57-'58 GH's and Avantis And of course Avanti Powered Larks and Hawks which are 3/8".
    President Member raoul5788's Avatar
    May 2008
    Cheshire, CT 06410
    2,067
    I thought all super charged fuel lines were 3/8".
    Chip
    '63 Cruiser
    '57 Packard wagon
    '61 Lark Regal 4 dr wagon
    '50 Commander 4 dr sedan
    Millsboro, DE
    2,212
    Quote Originally Posted by raoul5788 View Post
    Don't know if "all" supercharged cars had 3/8". Avanti, all, supercharged or not, have 3/8" from tank to fuel pump but 5/16" from pump to carb, and 1/4" return lines to tank.
    Apr 2012
    princeton mn
    2,767
    If your putting on all new lines I would go 3/8 as cost would be about the same and if you ever up grade to more power the line will handle it. We ran a 525 hp motor on a drag car with 3/8 lines and it always ran fine.
    7,747
    Yes, good advice. Getting even farther off-topic, check all the fittings in the lines as you upgrade. Alan reminded me a few days back Studebaker used some very restrictive fittings with holes smaller than 5/16"; so the smallest hole determines the flow of the entire system.
    Jan 2007
    waukesha, wisconsin, USA.
    318
    Avantis have 3/8" lines but my 63 R2 Superlark had 5/16" originally.
    james r pepper
