Originally posted by gerry r
View Post
Secondly, people get far too excited about oil pressure. Engines require oil flow more than they require oil pressure. If oil is being supplied everywhere it needs to be, pressure, which is measured before the oil gets anywhere it needs to be, is almost meaningless. Maybe counter productive. You could have 50 psi at the gauge and 2 psi at the rod and main bearings. And, of course, the oil pressure at the cam lobes and valve stems is always zero. And that's not a problem. Back in the good old days, folks thought they needed to run 30 wt oil because it gave better gauge pressures than 20 wt. But remember, if you use thicker oil to get higher pressure out of the oil pump it always means lower flow where the oil is needed.
Nowadays we think 5W30 or 0W40 is better because it flows more oil to where it is needed when the oil is cold and thick.
When the Lotus V8 came out, the oil pressure gauge was marked L-N-H because the normal oil pressure for that engine was 5 psi hot and people would have panicked.
You could dump a few bottles of STP in it. The pressure at the gauge will come up, and the amount of oil delivered to the bearings and elsewhere will be less. IMO, those viscosity increasers, polyisobutylene, like STP and others did exactly the opposite of what was wanted. They increased pump pressures, and reduced oil flow downstream where it was needed.
Or you could run 5W30, lower pressure at the gauge, but more oil everywhere it's needed.
Those old GMC pushrod sixes ran 2-3 psi at hot idle, and lasted a long time.
With no symptoms of low pressure - like bearing knock, I wouldn't get very excited. Does it run well without any unexpected noises? If so, keep calm.
